Standard fabricated pipe length
Could someone confirm that 60 foot length is a common fabricated length these days for 24" dia CS welded pipe.
If YES, any manufacturer name available?
Thank you in advance.
RE: Standard fabricated pipe length
How much do you want? I would not be convinced that this length would be held by a stockist, but a mill would probably make several kilometres for you.
It would also help if you gave us an idea where in the world you are, and what type of CS pipe you are looking for API 5L, A53 or just spiral welded.
Most plastic and metal pipes come in either 10', 18' or 20' sections.
I suppose you could special order any length though.
I am in Montreal, Canada and the pipe we are looking for is 24" CS STD.Wt. pipe / A106 B, is a steam line to be run on over 3.5 Km..
Have a nice week-end everyone,
If you are real close to a railyard, it may be even cheaper to get the longest pipe that can be put on railcars. Then local trucking to job site. I think you can get 80 footers on rail.
JTMcC.
http://www.acipco.com/steel/
The offer quadruple random lengths in some materials.
They are also an outstanding company, both to work for and do business with.
