Thread roll machine for Base Jack tubes
Hi
Please advise where I can enquire about a thread rolling machine to produce aprox. 700mm long OD 38mm (tube ID 24mm)standard Acme type of threaded rods - Material standard mild steel - we need to produce 50000 rods per year. The rods are used as part of Base Jacks in the construction building industry. Locally (South Africa) nobody seems to be interested to help.
Thanx for any leads!
RE: Thread roll machine for Base Jack tubes
I actually have an imported rolled (from Germany) sample in my office. One local guy produce a similar threaded tube from 5mm wall thickness tube. Unfortunately he is not interested in my requirement.
http://www.tesker.com/modComparison.html
Dick
Thanks for the help.
