2005 Animator
2005 Animator
Has anyone out there used the new animator? It looks like it does some things I wished 2004 did (like saving multiple animations), but I am having a lot of trouble learning how to use it (not the most user friendly program) and the help file is not very helpful. I am having trouble with two things: 1. I can not get flexible subassemblies to animate. I can drag them into position but when I run the animation they do not move. 2. I can not use interference detection to stop a moving part where I want it to stop so I have to drag it as close as possible. Both of these were not an issue in 2004. I am having other none related problems in 2005 but lets not go there right now...
Bob Snead
Designer
Northropgrumman.com
RE: 2005 Animator
RE: 2005 Animator
Bob Snead
Designer
Northropgrumman.com
RE: 2005 Animator
Bradley
RE: 2005 Animator
There is help for Animator in SW.
If you have the Add-in turned on - go to Help\Solidworks Animator Help Topics - If you don't get this option. Be sure you downloaded the help from the SW website on the download section there.
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
RE: 2005 Animator
I was refering to the on-line help where you actually do an exercise using a predefined example. Those were very helpful in understanding the basics.
RE: 2005 Animator
What sort of help do you need with the flex command? I don't have a lot of experience with it, but have done some messing around with is. Start a new thread and I'll see if I can be of any help.
Chris
RE: 2005 Animator
Is there a better tutorial on animation?
RE: 2005 Animator
Also, search google
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP2.0 / PDMWorks 05
ctopher's home site
FAQ559-1100
FAQ559-716
RE: 2005 Animator
To create an animation:
1) Click the Animation tab at the bottom of the window.
The graphics area splits horizontally.
The top area displays the model.
The bottom area splits vertically into two sections:
The SolidWorks Animator toolbar and Animator FeatureManager design tree on the left.
The timeline with the key points and the timebar on the right.
2) Drag the timebar to set the duration of the animation sequence.
NOTE: You can also click anywhere along the timeline to place the timebar, or use the space-bar to incrementally move the timebar.
The timebar is set for a duration of five seconds (00:00:00 to 00:00:05).
3) Drag the assembly component to the desired position at the end of the animation sequence.
4) To animate other assembly components:
a. Drag the timebar to set the duration of the animation sequence.
b.Drag the assembly component to the position desired at the end of the animation sequence.
NOTE: You can start the movement of additional components anywhere along the timeline. However if there is conflict in the movement between the components, a key point is displayed indicating unsolvable motion.
5) Click Play from Start to see the animation.
Also check out this file - http
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
RE: 2005 Animator
RE: 2005 Animator
RE: 2005 Animator
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
RE: 2005 Animator
RE: 2005 Animator
RE: 2005 Animator
Also try upgrading to SP3.0 as well.
Best Regards,
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
RE: 2005 Animator
BTW - I forgot to change my profile - I'm on SP3.0.
