pressure testing standards for hyd line
I am looking for pressure testing standards, particularly analog chart resolution requirements. How much percentage of a chart's scale should be considered acceptable (example: 7500psi test on 20,000psi chart is 37.5%)? I would expect to use between 60 to 80%. Is there a standard?
RE: pressure testing standards for hyd line
However, it's been a long time, so I stand to be corrected on any or all of the above.
Cheers,
Snubengr
I know of one standard that addresses this - API Spec 16C. During equipment tests, it requires that measurements be made in the range of 25% to 75% of the gauge full scale deflection.
Fracball
