Cable Insulation Resitance
I am specifying the testing of installed cabling, and once this is complete it will obviously have to be tested.  How do I determine what setting I should select on my megger i.e. 250V, 500V, 1000V ???
RE: Cable Insulation Resitance
Not higher than 2 x voltage rating
I thought it was 2x rated voltage plus 1000V? I know some manufacturers even allow testing at higher than this on their cable.
Megger or Hipot?
QCE - Using a Megger.  Testing cabling for a 240V supply (1.5mmm2) and Control Cabling (twisted pair).  Will both require to be tested at different setting depending upon the rating of the cable as mentioned by Ralph.
