Sick and tired of bugs in SW
Having over 22 years of design on 5 different CAD systems under my belt I am getting sick and tired of bugs in SW.
The latest - just opened a dwg that was previously saved a couple of months ago under SW 2004.
Now one of the views is totally messed up. Neither CTRL-Q, nor rebuilt helps.
RE: Sick and tired of bugs in SW
And this is not first time I see this kind of behaviour.
The SW DWG is total mess.
If you have a specific problem, list all the relevant details here & other forum members will try to help.
If you want to bitch & complain ... call SolidWorks or your VAR.
Try opening it on another machine... maybe it's your machine.
I have a customer right now that can't open a STEP file, but I am able to open it without question?
I found the problem. The problem was a corrupt Template. So the problem wasn't SW but rather a bad template. Things like that happen. So before you say it's a bug get it checked out with your VAR.
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
Just venting my frustration - what's the use of re-designed, "cool", "sexy" icons in SW 2005 ?? They should have spent their time on fixing the bugs - not on "sexy" icons.
The crop view is all ...... - up, the LAYERS are gone, so are the line thicknesses and style - instead PHANTOM layer, line PHANTOM, hicknes LIGHT, I get everything on layer none with everything standard.
On another dwg, when I tried to put dims between edge and hole on BROKEN view, the dims went heywire - I sent this to VAR, admitted it was a bug ....
Best Regards,
Heckler
"Never underestimate the power of very stupid people in large groups" John Kenneth Galbraith
IMO Solidworks is the best 3D CAD package out there for combined ease of use, functionality and $$$. Use it, love it, wouldn't change it for anything else yada, yada yada.
HOWEVER - it seems that all the improvements on new releases (or at least the ones we hear about) are geared towards being "sexy" rather than addressing some core concerns with stability and performance. Personally I don't care WHAT the icons look like if it means the program is going to crash only once a week instead of once every 2 days.
I recall being at last years SW world and during one of the presentations a list of the top 10 most frequent complaints about Solidworks from the very first edition of Solidworks was compared to a list of the top 10 complaints about Solidworks 2003. Something like 7 of the complaints were the same, things like "improve stability" and "improve large assembly performance". And what did they talk about in the preview of Solidworks 2005? Things like being able to project out an ISO view and the power-trim option in sketches.
Maybe that's just the nature of the software business - as you add functionality the program gets more complex so it becomes more and more difficult to keep it stable and fast.
Rant concluded.
How do I explain to my boss the fact that the older printed dwg he has in his office is O.K., but the dwg I printed right now, without any changes, is fouled up ??
Comment only:
Typical behavior - something good is finally created, then it succeeds and everyone is ecstatic that it finally exists, then it gets improved and promptly screwed up.
They did that to my favorite database program, at start rock hard simplicity and reliability (exactly what a database needs) - now in release 8.0 magnificant capability, it will do anything and everything -- but I wouldn't trust it with my data.
However, nothing said against solid and sustainable progress - only against incidental and gratuitous egomania.
Hopefully SW Corporation will re-assign its hotshot software developers routinely to their sales team to prevent them from wreaking their ambitions on a (probably) good product (or maybe a 6 month stint is enough to shrink their ego back to normal).
I've found some quirks in 05 concerning some of the more cutting edge sweeps or other features that were--let's say--not quite stable in previous releases. I would almost expect that since I've pushed SW in the past with so many work-arounds to get something it perhaps was not quite made to do.
For instance, I built the horn on my web site in SW 2003. If I perform a Ctrl-Q rebuilt, it crashes my main handle sweep. Bummer. Lots of guide curves and elliptical tangency for the profile--asking for some trouble in that feature anyway. I can rebuild it slightly differently in SW 2005 if I really want to, or I can let it be. If I need to return to that project, I'll rebuild it, but for now it's safely archived on a separate hard drive and on CDs.
With progress comes growing pains. The sweep feature has been strengthened in later versions, so I won't complain that my older sweep failed in this instance. All future sweeps will have the capacity of greater fortitude and options of greater complexity.
Jeff Mowry
Industrial Designhaus, LLC
http://www.industrialdesignhaus.com
Basically, it means you really can't trust the software as you upgrade if loft and sweeps change from version to version. It would be different if SW actually said in their product manual that upgrading will change your parts or files.
Our company make some models in sw to use them in some FEM fields, for example we made an engine block model which growed up exponentially in size up to 180 MB just for a part model !!!
It's wonderful that this model has a rebuild time about 21 minutes on a powerful workstation, and now consider that if sw regenerate this model with too many errors periodically , what should I tell to my boss ?!
It has errors or not ? Really I dont know !
We had same type of errors before on many models, one regenerated with errors on a machine and with no errors on another ! one regenerated with errors on a user login and with no errors on another user login and ...
Now in drawings , oooooof ... We have some big drawings about 200~250 MB , you have to praise the god if sw open one drawing correctly next time you've saved it, and so on you know better than me.
But I don't know with these huge number of bugs , why they don't have enough attention to fix them and just release the newer versions.
Best regards.
Heckler - Join the Beta testing team. Get on Early Visibilty for SP's. If you want it tested then you can partcipate in the testing yourself. Then you can have first hand knowledge of what's going on. If you choose not to (IMHO) then don't complain. That is what the Beta testing is there for. I think if you search this type of thread up. This was discusses extensievly already when SW05 came out in beta.
Scott Baugh, CSWP
FAQ731-376
Wouldn't it be considered a bug if the part should have failed but didn't?
Best Regards,
Heckler
Most of us don't have the luxury of spending 1 to 2 weeks working on a 3000 part assembly (like we would for production use) if that assembly might meet an untimely end. Also - the software sometimes changes so dramatically between the beta and the full release that it's difficult to be sure that what DID work in the beta will still work in the full.
The ONLY way to truly iron out the bugs is to use the software in production, which is why some places only update every 2 or more releases, and why in general it's not a good idea to update until at least the first SP comes out.
But, getting back on topic...
Documents changing between releases is unfortunately a fact of life as the software improves so we all just have to live with it and hope that eventually the program will one day be "good enough" and no more improvements are needed.
I first learned on SolidWorks 96, worked with it up untill 2001 Plus, then I was let go from the company I worked for. I was away from SW for about 2.5 years, and have recently been able to convince the new company I work for, to switch to 3D design. I've jumped right back into this game, whithout having to fight it much, to me that says something for the software. I know I'm kind of getting off topic here, so I'll quit with this. Try going back to Autocad for a couple of years, I bet you'll be begging to have SolidWorks and it's quirks, back on your desktop.
Later
Chris
I really don't think we can say the SW people are a bunch of slackers when they have the best option. The more complex the software, the greater the likelihood of some glitches. (The same goes for any high-performance product. How does a top-fuel dragster engine compare with the engine of a Ford Taurus? Come on!)
Jeff Mowry
I am satisfied with the SW2005 0.1 release. It has been much more stable than SW2004. I like the flexibility it gives and the new features. It is getting better.
I didn't mean my reply in a negative way, just wanted to make sure you understand that it is tested. But thanks for the clarification!
engAlright,
Why did the beta release of SW05 find over 3000 bugs and SW fixed them all. Do you really want that many bugs in your released Software? I think not. I think the Beta Program paid off because this release of SW is the best so far, for a SP0.0 and .1 SP.
If you have a standalone seat of SW at work, you can take that same seat home and use the software at home. If you have time to fiddle around with it, that's great. It's better then nothing at all.
I think the Software is already "Good enough". It has it's problems, but there isn't much you can do about that. It's was created by "Man" and you know what happens when "Man creates something. I will eventually break.
There will always be improvements because the new Enhancements are from users like yourself. You can almost always count on Improvements.
Scott Baugh, CSWP
FAQ731-376
However, what makes the software potentially dangerous is the way that it can reinterpret your design from version to version. That is not good practice. Supposedly the way lofts are done can change from version to version.
Now my point is this, what happens in the future when CAD models become the standard reference for a part? How can any sort of trust be had between the software model and what should be manufactured?
For archival purposes, what would be needed to be saved on a optical disc? The 3d model as well as the specific software package and sp necessary to recreate it?
And Scott, how do you define a bug in a user's process?
Unfortunately if we choose to upgrade early and/or without a clear plan (perhaps also even when things are planned carefully even) then I personally think that it's virtually inevitable that people will experience the proverbial "bumps in the road." Having said that, it's probably a good idea to mention archiving SW databases to preserve data before upgrades (I think it's actually recommended by SW if I recall correctly anyhow). Obviously in some cases that's prohibitive but giving some forethought does seem warranted to prevent/minimize headaches.
All in all SW has some work to do in order to alleviate some of the colorful language emanating from our department since we upgraded to SW05. For the record, despite the collective dischord the guys I work with are generally very satisfied with SW otherwise.
Speaking for me I can do more today with SW than I could even a year ago (and the year before that, etc.) and I expect it will continue that way for the foreseeable future. No doubt in my mind it is a good package. And while I too perceive some of the "sexy" fluff that they've been trying to sell me for years to be superfluous there are useful, productive and functional upgrades which have been incorporated into every new release that have made my life easier (Sheet Metal, Surfacing, Sweeping, etc.).
Yeah, it sucks when a "bug" hoses all or part of something we've worked on for many hours but I do know from experience that our VAR and SW tech support have bent over backwards to straighten out problems with/for us. Get on them and let know what your problem is. In the end it does serve the larger interests of the entire SW community oftentimes.
Chris Gervais
Sr. Mechanical Designer
Lytron Corp.
Missed your post earlier.
Yes it would be considered. But what if this wasn't ever caught. The user would not think of something workign as being a bug. Would you? I wouldn't... but there might be a similiar issue that is repaired or maybe some else did point this out and turned it in. So in the next release the part fails. You immediately assume it's a bug. When in fact it's not.
I can't say often this happens, but it's another way of thinking about it before acting on "IT"S BUG!!!" HELP!!! - You get the idea.
Best Regards,
sirmick,
How do you mean? Define a bug in a user's process?
The user must give me a list of steps andm aybe files to reproduce the issue at my station. If I can reproduce then I have Legitimate issue I can turn into SW. I add the steps provided by the user and any other information that I tried to do to get around the issus, unless it's just plainly obvious.
Best Regards,
Everyone
There are going to be all users that think differently. Some think like "Cryo1"
and there are others the feel like ctopher
I feel that ctopher's post is showing the love for the use the software. He want's to get the best product for his money and is willing to help SW make it better. Since after all that is way the product is out there. To make the customer as happy as possible. I feel the same way and now that I am on the inside a little bit. I feel like I might make a differenece. then again maybe i won't but I know I'm passionate about this software and I have been for years (since 95-96.)
FYI - Below is meant in General and it is not pointed at any particular person or group. Cryo1 I used your quote as an example.
But you have the choice not to join the beta testing and that's fine. But don't expect perfect software, because it's software. I don't expect perfection, but I do have expectations every year for the software and only once have I seen a bad release. Since then they have made up for it. If you want to complain about bugs find go to comp.cad.solidworks and complain all day. If you want help then come here and we will help to the best of all our abilities.
Beat Regards,
Scott Baugh, CSWP
FAQ731-376
I had SW crash three times in a mater of an hour, now i know what not to ask of it, but got the job done much quicker that the other packages.
Don't mind the bugs, because they will eventualy iron them out. Having said that Inventor does have a more comfortable drawing system.
Conclusion: i must go do some fishing soon, or i will just explode.
