SW2004 sp4.2 macro error
I recently went to sp 4.2 in sw 2004.  Now one of my macros won't run.  The line that crashes it is
Set swApp = Application.SldWorks
The error it gives is
Compile error:
Object library feature not supported.
The visual basic debugger which comes up is version 6.3
Any suggestions?
RE: SW2004 sp4.2 macro error
change
to
set swApp=CreateObject("Sldworks.Application")
"Customer satisfaction, while theoretically possible, is neither guaranteed nor statistically likely.--E.L. Kersten
http://www.EsoxRepublic.com
Perhaps your VBA installation is corrupt.  Check the FAQ's in this forum about that subject.
p.s. please keep your replies on this forum so others can see progress
One more thing to try...
In the SolidWorks VBA macro editor, make sure the reference to SW library is still there.  Look under "Tools --> References" and make sure the "SldWorks 2004 Type Library" is checked.  It's a long list, look carefully.
