Lee Kesler Spreadsheet
I have been trying to create a spreadsheet to come up with residual properties via Lee-Kesler EOS I have however hit a snag. In Lee-Keslers paper he describes a term Vr=Pc*V/Tc*R where V is the volume of a simple fluid. The paper I am refering to is called "A Generalized thermodynamic Correlation Based on Three-Parameter Corresponding States". And I could REALLY use some advice
RE: Lee Kesler Spreadsheet
HAZOP at www.curryhydrocarbons.ca
For another reference, see Chapter 7 of the API Technical Data Book, Hydrocarbons. This covers thermal properties, and the LK procedure for dH and dS is described well in there.
First, determine the ideal reduced volume of the Lee-Kesler "simple fluid" (w = 0) using the Tr and Pr of the fluid of interest. Calculate the simple fluid compressibility (Zsf = PrVr/Tr).
Second, determine the ideal reduced volume of the Lee-Kesler "reference fluid" (n-octane, whose w = 0.3978) using the same Tr and Pr of the fluid of interest. Calculate the reference fluid compressibility (Zrf = PrVr/Tr).
Lastly, find the compressibility of the fluid of interest by interpolation/extrapolation based on the acentric factor of the fluid of interest. [Z = Zsf + (w/0.3978) x (Zrf - Zsf)]
The 3rd Ed. of Sherwood, Reid, and Prausnitz has all the equations and tables you need.
Good luck,
Latexman
Good luck,
Latexman
