Bearing isolators
Bearing isolators
Bearing isolators
I have to order a bearing isolator for an application, but I haven´t been able to take the necessary measures of bore diameter, shaft, nearest obstruction, etc. But the personal at field have a replacement in stock which has the following code, 1750A-01312-0 and 1700-R-02495-5, this is a bearing isolator provided by Impro Seal.
Does anybody knows what this code means?
Thanks in advance for any help provided
RE: Bearing isolators
Impro has a very responsive customer support organization. I would recommend ask your sales rep to help you get the info.
