Keep the visibility state between configurations
Well, may be this has been asked before, but because the search engine does not work, here I go: Is there a way to keep the visibility (hide show) options between configurations? I want to hide or show a component in one config. and keep that state for ALL the rest of the configurations, in order to avoid manually do that. I don't want to hide or show some components in all my config's when I want to see some details.
Thanks in advance
Thanks in advance
Adi Corrales Magallanes
Centro de Ingenieria y Desarrollo Industrial
Queretaro, Mexico
RE: Keep the visibility state between configurations
I'm not sure if this option is available when making derived configurations.
So I guess I need to ask what kind of configurations do you have? derived or regular?
A man should look for what is, and not for what he thinks should be. -Albert Einstein
A person who never made a mistake never tried anything new. -Albert Einstein
Queretaro, Mexico
Queretaro, Mexico
1) You then place $Show@Component_Name<Instance> in Column "B" Row "2" Use your component name and instance. Do this for each column. You do this for the total amount of parts you have.
2) Then under column "A" Row "3" and below you place the Configuration names you want in your assembly.
3) Then under each component per config you can place a Y or and N. This will show or not show the files. Y = "Yes", N = "No".
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
Once each configuration is set. then you can go to each configuration and hide and supress components.
I don't think there is any other way.
