double outlet blower housing
I'm installing a blower in a machine roof panel and have come accross a problem: The blower exhausts into the side wall of a long, narrow passage. The two close walls create flow problems. Has anyone ever seen a blower housing that has two opposing exhaust paths, instead of one?
RE: double outlet blower housing
As with any air mover, the performance curves assume no restriction at the exhaust, so you'll have to figure that into your calculations.
ko (www.ecooling.biz)
