Diplay template Contour or Element?
Hello all,
I did an FEA on a vehicle suspension part. When I postprocess the results. There are couple of options in the display template menu. I first selected the contour and I got about 10 ksi maximum stress and 1.19E-2 in max deflection.
Then I selected the element on the display template menu and corresponding results were 22 ksi and 1.19E-2 in.
What is the difference between the contour ans element results. I use ideas 9.
Any help will be appreciated.
Thank you.
umit
Thank you.
umit
