linking to an Excell file with SE version 16
I'm having problems with the stability of files when linked to an Excell document.  I can take a model and change dimensions without losing any features.  With the same model I can link the same dimensions to an Excell spreadsheet, change them in the same way and have multiple unrelated features fail.  When this happens the failed features will have a red exclamation point beside them.  When you place the pointer over them they simply say "failed to recompute."  I also have problems with the files displaying and updating correctly in SE draft.  If nobody else has had these problems, I'll assume I'm stupid.  What I really suspect is that the SE programmers are.
