Catia V5 transformation matrix
Hi, Is it possible to view the transformation matrix for parts that have been moved within a product. Is there a command to see this or a Catscript that will report it back to me. I would like to see the matrix a bit like when you select on the links in a VPM PSN graph and look at the transformation. Thanks
RE: Catia V5 transformation matrix
Warning: I have had a problem with this not updating, but I believe that it is an problem with the installation, rather than with the method.
Mike
