Configurations often do not come in as chosen.
I have several simple bolts that have configurations for the length. Often (but not all the time) when I insert for instance a M8 X 25 configuration it may come in as a M8 X 35. When I check the properties the use named configuration is checked. I simply have to reselect the config I need and it will correct itself. Is there some global setting for an assy that over rides my selection?
TAP
TAP
RE: Configurations often do not come in as chosen.
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
You can open the part first and in the open menu you can select which configuration you want to use. Then you can drop that part into your assembly, but this takes up extra procedures. you might as well just do it the way you are now.
Scott Baugh, CSWP
FAQ731-376
TAP
Of course when I add more then one part into my assemblies and check the properties of that parts Config - "Use Named config" is already highlighted.
Scott Baugh, CSWP
FAQ731-376
