problem with script
problem with script
problem with script
i have a project and every time i run it it gives me this "??? Error: File: C:\MATLAB7\work\square.m Line: 15 Column: 26
Missing variable or function." i have spent many days and i still can't figure it out. there are three parts to the script the main (square.m), the function (fsum), and the given material (pwrspec.m). the problem doesn't make sense, at least to a novice like me. here is the all of the script:
square.m
clf
%trying to find a square wave
time = [0:0.01:10];
T=10;
omega=2*pi*1/T;
fsummation=0
k=1;
gc = ['b','c', 'm', 'k', 'y','g', 'r', 'b'];
for ndx=[1:2:19],
farray(k,:) = fsum(time, omega, ndx);
subplot(10,2,ndx)
    for m=1:k,
    hold on
    gc(mod(k,8)+1)
    plot(time,farray(m,:)’gc')
    end
fsummation = fsummation + farray(k,:)
subplot(10,2,ndx+1)
plot(time, fsummation’r’)
k=k+1;
end
gtext('Archie Brentano SN')
figure
pwrspec(fsummation, 1000,100)
gtext(‘other name’)
fsum.m
function fsum(time, omega, ndx)
%fsummation
fsum = 4/pi*1/ndx * sin(ndx*omega*time)
pwrspec.m
function pwrspec(signal, N, srate)
% pwrspec(signal, N, srate)
% pwrspec computes the power spectrum of a signal and creates a plot
% signal = vector containing signal values
% N = desired length of vector, normally obtained from "length()" function
% srate = sampling rate used to calculate signal, typically twice the value of
%         highest frequency
P = fft(signal,N);
n = length(P);
plen = floor(n/2);
power = abs(P(1:plen)).^2;
nyquist = 1/2 * srate;
freq = (1:plen)/(plen)*nyquist;
stem(freq,power)
title('Power spectrum of signal stream')
xlabel('frequency (Hz)')
ylabel('signal intensity')
grid
RE: problem with script
Looks like it doesn't like your plot(time,farray(m,:)’gc')
I'd guess a missing comma.
Cheers
Greg Locock
putting the comma in, just changes the error say: "??? Error: File: C:\MATLAB7\work\square.m Line: 16 Column: 27
Missing variable or function." so that doesn't seem to change the problem all that much
square.m
clf
time = [0:0.01:10];
T=10;
omega=2*pi*1/T;
fsummation=0
k=1;
for ndx=[1:2:19],
subplot(10,2,ndx)
    for m=1:k,
    hold on
    gc(mod(k,8)+1)
    plot(time,farray(m,:),’gc')
    end
subplot(10,2,ndx+1)
k=k+1;
end
figure
gtext(‘other name’)
Well, the advantage of a modular language is that you can go into debug mode. Write some routines that test each subroutine by itself. Comment out the parts of the code that are not essential to its function, such as plot...
Incidentally I can't say I like the look of gc(mod...
either but that may be you doing something fancy to an array of strings, not the sort of thing I do.
Cheers
Greg Locock
There are some errors spread out through your code
  1. You use instead of ' several times.
  2. The fsum function has a VB-like syntax that doesn't work in matlab.
    CODE
    function out = fsum(time, omega, ndx)
    %fsummation
    out = 4/pi*1/ndx * sin(ndx*omega*time);
    is much better.
  3. As Greg said, gc(mod(k,8)+1) is wrong. Something like this is better.
    CODE
    color=gc(mod(k,8)+1);
    plot(time,farray(m,:),color)
The pwrspec.m doesn't seem to have any errors.
This was what I found when giving it a quick look, there might be more problems.
well i finally got it to work. here is the code if anyone wants to know:
square.m
clf
time = [0:0.01:10];%gives the increments of measuring for time
T=10;%the amount of time it takes to run through the run
omega=2*pi*1/T;
fsummation=0;%starting parameter for the right graph
k=1;%starting inner and outer variable
gc = [ 'k', 'b', 'g', 'r', 'c', 'm', 'y'];%color array
gh = 1;%labels the title of Square wave
gp = 1;%labels the title of partial series
u = [0, 10, -1.25, 1.25]%limits the axis of the graphs
pr = [0, 6, 0, 60000]
for ndx=[1:2:19],%this is the index which tells the script to run on the odd numbers
    subplot(10,2,ndx);
    for m=1:k;
        color=gc(mod(m,7)+1);
        plot(time, farray(m,:), color);
        hold on
        if (gp==1)
            title('Partial series: 1,3,5,7,9,11,13,15,17,19')
        end
        gp = gp + 1
    axis(u)
        if (ndx==19)
            xlabel('sec')
        end
   grid on
   end
fsummation = fsummation + farray(k,:);
subplot(10,2,ndx+1);
plot(time, fsummation, 'r');
k=k+1;
    axis(u)
   if (ndx==19)
    xlabel('sec')
   end
    grid on
   if (gh == 1)
   title('Square wave synthesis')
   end
   gh = gh + 1
end
gtext('Archie Brentano SN: 930-584-308 ECE111 Fall 2004 ')
figure
axis(pr);
gtext('Archie Brentano SN: 930584-308 ECE111 Fall 2004')
fsum.m
%fsummation
%time is a time-axis vector
%rfreq is the radian frequency
%idx is the square wave synthesis degree index
%fsum will calculate a term of a series of sine waves that will approach a square wave
pwrspec.m
%         highest frequency
P = fft(signal,N);
n = length(P);
plen = floor(n/2);
stem(freq,power)
grid
thank you.
