Power outage prediction by Hz-monitoring??
Is the mains frequency of 60 Hz nominal a reliable health sign for the power grid? If so is then a viable solution preventing power outages by letting loads automatically disconnect from the grid, if the mains frequency drops below a certain limit? Or is it also necessary to keep an eye on the voltage? How low a mains frequency should still be accepted as an ok level? One could also measure the frequency-change over time (df/dt) if that would be more accurate.
This stuff is surely basic knowledge for any power engineer, but being "only" a computer engineer I am completely blank on this subject. Appreciate inputs –THX.
RE: Power outage prediction by Hz-monitoring??
Do a web search on "load shedding" and you find a lot information.
