20Ni - 9Cr Alloy
20Ni - 9Cr Alloy
Dear Guru's
Does any one have an idea about a 20Ni-9Cr-0.2C-0.7Mn-1.0Si alloy?
Is there a specification which covers this alloy?
RE: 20Ni - 9Cr Alloy
It is a steel with 20Ni-9Cr-0.2C-0.7Mn-1.0Si-0.05P-0.05S-balance Fe.
Thank you
This is similar to some high temp alloys, but it lacks any of the elements needed for high temp strength.
Is this a cast or wrought product?
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
From what I was told, it was for tubing made by Centrifugal Casting Process. I dont know the environment it was going to be used in.
Thank you.
