Running 50hz on 60hz
I have a drill press that I bought over in Europe, so it is 220/50. I have looked through many post here and have seen that if you go 60hz to 50hz you lose power.
If I go from 50hz to 60hz will it burn up my motor?
Thank you for your help
RE: Running 50hz on 60hz
If we learn from our mistakes,
I'm getting a great education!
If you use 220VAC/60 Hz. you should be fine. the motor will run faster by about 20% and produce slightly more power.
The US 120VAC/60 Hz system is a Phase to neutral arrangement where as the European system for the most part is a duel phase system or what is called a single phase system (a misnomer in my most humble opinion). Not trying to muddy the water, but the two systems differs very little it design other than the Frequency and the US phase to Neutral application.
Anthony “Redmane” Milford
The European system - for once I will accept that the UK is in Europe, geographically if not politically - does not typically run a 'two-phase' system as you describe, at least not in northern Europe.
The majority of European systems are 400V/230V with 230V being the line-neutral voltage. Your humble opinion is, in this case, also in error.
There are huge differences between the NEC in the US, the BS7671 IEE Wiring Regulations in Britain, and whatever the rest of Europe uses. Even within Europe we can't agree. The electricity itself is similar, electrons being electrons everywhere, but it is untrue to claim that the US and European systems are broadly similar. In some respects they are poles apart.
You are most correct, I should have been more concise in my answer, and yes, my humble opinion was in error. Oh! Did not mean to insult the UK by lumping it together with continental Europe, please excuse my over generalization of the topic.
