auto-transformer for grounding purposes
My question is:can an auto-transformer (not a zig-zag)
derive a netural for a high resistance grounded system?
If so,what are the limitations and if not,why?
Thanks in advance for any ideas or thoughts on this subject.
RE: auto-transformer for grounding purposes
No, you can't create a neutral with only an autotransformer.  Basically, you need a zig-zag or a wye delta connection to provide a path for the zero sequence currents to flow.
