shear & tension in anchor bolts in piers
Does anyone have a feel for a maximum shear value when using anchor bolts are in piers? Thank you.
RE: shear & tension in anchor bolts in piers
In the AISC Manual of Steel Construction , Ninth Edition (ASD) take a look at both the code and commentary in Part 5, Sections J3.4 and J10.
Also check ACI 318-02 Appendix D.
