Transversly Isotropic Laminites
I am working on an analysis of a carbon (balanced cloth) laminate structure and was told that when assigning material properties, to assume that the lamina are transversely isotropic i.e. the G12=G13=G23. Does anyone have a reference as to why this is or is not a valid assumption? I feel that the stiffness in the transverse directions is going to be epoxy dominated and therefore much softer then the in-plane stiffness (610,000 psi for balanced cloth). Thanks in advance.
Erik Carlson
Erik Carlson
RE: Transversly Isotropic Laminites
