Runtime Error!
Runtime Error!
Runtime Error!
Has anyone ever seen this error msg?  I seem to be getting this more and more often now when trying to open certain files.  (which open fine on other pc's in our office).
Microsoft Visual C++ Runtime Library
Runtime Error
Program: D:\SolidWorks\SLDWORKS.exe
adnormal program termination
Ive got a pretty good new system too:
P4-3.2GHz
2gig Ram
80gig SATA hd
winXP Pro (SP2)
Solidworks 2005 SP0.1
Our server needs to be upgrade though...We are running 3 computers off a win98 box (fat32)!   Im not sure if that is whats causing this particular error though.
RE: Runtime Error!
maybe turn off virus/firewall protection and reinstall SolidWorks?
RE: Runtime Error!
Whoa!  Windows 98?
I'm not sure, but you may have hit a RAM allocation limit of some sort.  I never use servers to access applications, so I might be way off here, but I'd imagine this would be a major problem--especially since Win 98 isn't supported by SW (especially not new versions).
Jeff Mowry
Industrial Designhaus, LLC
http://www.industrialdesignhaus.com
RE: Runtime Error!
Yeah im running SW05 sp.01.  I have a feeling the new "Collaboraton" feature is causing some of the problems. Maybe it isnt compatable with win98!  We are looking into getting a basic server for our 3 design computers here.  Any server suggestions??  :D
RE: Runtime Error!
Consider AMD Opteron 64-bit chips.  Lots of bang for the buck.  Other than that, I'm no use for advice in servers.
Jeff Mowry
RE: Runtime Error!
Yeah i've always been an AMD fan. But all the companies i've worked for, didn't want anything to do with them.
Well, i switched OFF the "/3GB" Windows switch, and my system seems to be a bit more stable.  I've also lowered my page file back down to 2GB (initial/max).   So far so good..... All in all it still doesn't make any sense why it should be more stable!....
RE: Runtime Error!
The problem is obviously in your machine & you probably need to do a repair or re-install. Have you tried working through the FAQs suggested in SBaughs post?
