plastic gears transmitting drive
hi
I want to cut gears on two plastic blank of 6mm thickness.The first blank is to be 50mm rotating at 3rev\s and is to drive the second blank (gear) which is to rotate at 50rev\s with a weight of .5kg.
I will like to know the number of gears that will be on the driver and driven.
I will also want to know the type and size of gear that best fit the job.
thank you and God bless you.
