TN-S-C problems?
TN-S-C problems?
I have to feed a building from my main distribution board. I have sized a breaker an 4C cable accordingly. The cable will be armored so that i will also be providing them with a PE via the metal sheath. From my point of supply till their input the system is a nice TN-S.
The problem is that their input point was previously a service input, and for reason X, the distribution system within that building cannot be known. So i'm thinking that if it's a T system inside or a continuation of the TN-S, i'm fine. But if the distribution inside the building has the N and the PE linked or one and common, my guess is that the breaker i've put for them in the MDB will keep tripping with a Neutral-to-Earth fault. If i don;t send them a PE i might have maintained leakage and hazards.
Is there a way i can make sure the building is supplied, no matter what IEC connection is used inside?
RE: TN-S-C problems?
Sorry about that.
