VB6 Running Another Program
Ok I work at a store were every night we have to run a program and follow certain steps with in the program. Thw hole process takes me about 15min. I was wondering if there is any way I can write a VB6 program that will do the steps for me.
I guess im asking make a VB program were all I have to do is click one button and the VB6 program will do all the steps in the other program??
Please help!!!!!
Please help!!!!!
RE: VB6 Running Another Program
Bill
Is there a return value issue? Do the results of one program feed into another, or is there a conditional based on the results of one program?
Is there a sequencing and timing issue? Is is necessary to wait on one program to complete before starting the next?
Good Luck
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
Just as CajunCenturion said it is important to understand the order of the steps in your process which you want done.
If you do this with batch jobs the payback will just about be immediate.
You will have to create your own macros. Depending on what programs you are running it can be quite easy.
Be sure to test the program and try to anticipate problems such as the computer going down due to loss of power or whatever else can occur in you environment.
Bill
Jon
