Building new parts from assemblies
I am to design some new parts that fit on a specific shotgun receiver. I have a SolidWorks solid model of the shotgun receiver, except that it is in the form of an assembly (actually a .SAT file that I can import).
It would be simple enough for me to make the required sketches for the new part using the Convert Entities tool, but I can't do a boss extrude on a new part from inside an assembly drawing.
The assembly breaks down into a number of parts files, but it's the assembly as a whole I need to mate to with the new part.
Is there a way to blend multiple parts into a single body in an assembly? Or some way to build new parts in an assembly? Or a generally accepted method for building new parts from an assembly?
RE: Building new parts from assemblies
Check help files on this for more details.
Jeff Mowry
Industrial Designhaus, LLC
http://www.industrialdesignhaus.com
1. All components
2. All faces
3. Exterior Faces
You probably want the all components selection.
This will effectively create a part file of the entire shotgun. You will however lose all the associativity of the assembly to the newly created part. In other words, if you update a part in the gun assembly, it will not update in your newly created part file.
I have used this method in the past to "merge" a supplier's assembly into an off the shelf part file. I have also done the same with assemblies that my company manufacturered that were designed into a customers bigger system. I created a part file of my assembly and emailed that. They had no use for all of the parts in my assembly, and I didn't want them to have all that intellectual property anyway.
You probably created the sketch at the assembly level instead of in a new part, which would explain why you can't do a boss extrude. You need to be editing a part.
