PDF files from UG/NX2 drawings ???
Is there a utility to create multi-sheet PDF files from UG drawings?
RE: PDF files from UG/NX2 drawings ???
not directly.
Plot the files to disk as HPGL
Use pdf995.com software to print a pdf from some HPGL file viewer.
"Fixed in the next release" should replace "Product First" as the PTC slogan.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
Adobe Acrobat Pro allows you to merge PDF sheets together into a multi sheet document... so you can plot to individual PS files, distill them into individual PDFs, then merge them in Acrobat... but that may not be what you are reqesting. Ben's method may be the best way to do that, except that there is still a secondary operation involved, but you can simply write a .bat file to merge the .hpgl files, then print them to PDF via pdf995.
-Derek
DL Engineering Services
specializing in CAD Design Consultation Services
www.dl-engineering.com
I do not have a direct link to a download, but at my last job we used a post script program. From the plot menu it would make a .ps, then we opened it with ghostscript, then convert it to PDF.
Keith Young
Walway Enterprises
UG Tool Design
Just export a CGM file and import it into Adobe Illustrator.  You can save a PDF with Illustrator.
Search for FreePDFXP
In conjunction with Ghostscript 8.x it allows You to save
a .ps in a folder (eg c:\PDFOUT) then convert it with just a double click.
For large formats (ISO A0...) You will need to tweak the driver of the virtual printer switching from the default apple PS printer to a plotter that support PS (E.g. HP designjet 3500CP PS3)
FreePDF XP license
· FreePDF XP is a Freeware (also for companies).
· the author is not responsible for possibly Damage, which is caused by a use of FreePDF.
· the author does his best to release virus-free Software. The author is not responsible however for
damage, through possibly Virus infections.
· for the software there is no email support for free.
· you receive support to FreePDF XP in the manual and under http://shbox.de/english.htm.
· label names used in the software are own of there owners.
· FreePDF XP may not be sold. On booklet CD's of magazines FreePDF XP can be delivered.
· The Program Redmon is licensed by the Aladdin Free Public License
· author of FreePDF XP is Stefan Heinz
If you use Omniformat along with pdf995, it automates the entire process.
http://www.omniformat.com/
-Dave
Everything should be designed as simple as possible, but not simpler.
