Detail Drop Down Menu in ABS2004 & 2005
I have been using the “Material Compose” function in the “Detail” drop down menu in ABS-2004.  I cannot find “Material Compose” in ABS-2005, and when I use “menuload” to import the Detail Menu, it does not work.  Any suggestions?
RE: Detail Drop Down Menu in ABS2004 & 2005
HI,
I have not used ABS-2004 but some of our add-ons to Autocad require a support path first(to be first in the list of paths), and then menuload, and then a Autocad restart.
Just a thought.
I don't use Building systems, but I do use ADT.  The details program has changed quite a bit.  I don't think it has a pulldown to use anymore, as everything has been converted to the palletes.
