High Pressure Sodium Hyperchlorite injection
Can anyone advise ?
I have a situation where I need to dose sodium hyperchlorite into a trunk main supply with operating pressures in the range 18 - 22bar.
This resticts me from using a standard PVC lance as these are only rated to 16bar. I have been told that a titanium lance would be suitable as this would accommodate the high pressures and is resilient to Cl.
Would this be the solution ? Any guidance would be appreciated.
RE: High Pressure Sodium Hyperchlorite injection
Do a lookup for "injection quill" on the web.  You will find many companies with many different quills.  Saftflo is one of those companies with various injection assemblies/parts.
You can get them in PVC, Polypropylene, S.S., Hastelloy, etc.  The S.S. and Hastelloy will hit pressure ranges higher than what you are talking and they should handle the CL.
Misco 41
Hypo will eat the stainless steel (any grade) injection lance/ Quill
But Hastelloy C as I remember is good for chlorine gas and Sodium Hypochlorite.
Hope this helps
semo / Tonka73,
Many thanks for your reply. I have been advised that Hastelloy is extemely difficult to machine, and work hardens terribly ? Any commnets...
You could probably find a made-up lance. Try Nalco
misco41
Hastelloy injection quills (ready to go) are available in USABluebook, stock #29384 for the 0.5 inch size for $235 www.usabluebook.com
Hydrae
