Design Cold formed Steel section as per BS code
Hi All
Please anyone can help me, where I can get Cold formed Steel section, is any code book and tables as per BS code
Thanks & Regards
Sreedhar
RE: Design Cold formed Steel section as per BS code
I'm not sure I fully understand you. Cold formed steel is designed to BS5950 Part 5. The shapes of the sections used are determined by the manufacturers and they publish this information together with 'safe load tables' for the normal loading conditions.
