Display options
Display options
Display options
How can I if vthere is a possibility (in Config.pro or somwhere else) set
a) View Model>Display >Shade> Quality(10)
b) Tools>Environment>Display Style>No Hidden
Now I must do that procedure every time I open proE
RE: Display options
Hi 427591HJ,
In config.pro, set DISPLAY to hiddeninvis. (WF)
I'm not sure you can change the shade quality in config.pro, unless it's a hidden config that someone here might know about. you might have to set a mapkey to do it.
Hope this helps!
gwen
