AutoCAD file properties in Excel
THANKS IN ADVANCE FOR READING THIS!!!
I currently have an excel spreadsheet that contains hyperlinks to dwg, pdf, and doc files. Is there any way to start a column(s) that would list certain file properites, such as Date created and Date modified, where the information could be easily updated automatically (excel would obtain the file properties)? Also, is there a way to indicate in excel that a referenced file has been saved as a different file name?
Please HELP!
-John
Please HELP!
-John
RE: AutoCAD file properties in Excel
as far as links to other files, try "edit" and "links". there will be a listing of all links to other files.
good luck!
-pmover
CODE
FileDate = FileDateTime(f)
End Function
Cheers,
Joerd
Thanks!!
Cheers,
Joerd
