[b]Section line weight[/b]
I'm having trouble changing the section line weight in a drawing. When I create a section view, the default weight for the section line is thick. When I attempt to change it to thin weight in the Component Line Font menu, nothing happens. Is there another way to do it?
Tom
RE: [b]Section line weight[/b]
Try:  TOOLS - OPTIONS - DOCUMENT PROPERTIES - LINE FONT
Remember...
       "If you don't use your head,
                       your going to have to use your feet."
I got it.
It was actually the view line in the auxillary view that I needed to change, not a section line.
