Pro/Report and Simplified Reps and exploded view - Urgent Help
First, I have a final assembly that has a simplified rep name rep0001. The rep only shows all the plastic parts of the final assembly - every thing else is excluded from the rep. approximate 24 parts showing from 146. now lets talk exploded view - I have created an exploded view - nothing fansy just exploded. Now lets talk drawing, I have created one view - an exploded view (same one mentioned above). Now lets talk Pro/report. I have a BOM that currently reports all the parts in the final assembly. My goal is only report those that are present / showing in the Simplified Rep. I noted in the Create>table>repeat region> modl / rep, that I can use it some how. Can someone help me create a BOM that only report a simplified rep. Thanks Texaspete
RE: Pro/Report and Simplified Reps and exploded view - Urgent Help
It's simple this one. Create your BOM table (or just the repeat region) AFTER you put the simplified view in the drawing.
-Hora
dave.maloy@curious-id.com
You must create the repeat region AFTER you put and set the simplified rep view in your drawing. In this way you'll have the link between your BOM and the view. This is what is missing in your drawing.
Then you can add the text:
&rpt.index| &rpt.qty| &asm.mbr.name| etc etc
There are no special parameters for the simplified reps. You need only to link the BOM with the simlified assy.
-Hora
I add the text:
&rpt.index| &rpt.qty| &asm.mbr.name| , just like you have it and it working - almost, Do you have any insight.
Thanks Texaspete - Ps, I will be here Friday.
I think I found your problem. If you have ProE2001, then go to VIEWS->DWG MODE->Set/Add Rep and choose the simplified rep you want to apply the BOM. Then erase the repeat region and recreate it. This shoul work for you. Keep me in touch.
For Wildfire should be similar.
-Hora
Keep in mind that repeat region are linked with the default model. If you have several models (assemblies) or simplified reps, make the one you want to add the ballons default, and then create the repeat region in your table. You can have multiple BOM tables linked to each assy/simplied reps.
Good luck.
-Hora
