Structural Analysis of Box Culvert
I am reviewing the structural design of precast box culvert manufacturer and need some clarification. The culvert will be produced as "clam shell" sections (upper and lower halves) with shear key to prevent lateral movement. When analyzing as a frame using moment distribution, I am unsure whether to model the joint at the shear key as a pin, fixed, or roller support. The precast engineer assumes the culvert wall acts as a cantilever beam for fixed end moments with the horizontal thrust acting at the shear key. Also, could you advise as to sources of literature available for design of box culverts.
RE: Structural Analysis of Box Culvert
Good luck
Stan
Stan
Ron
