1045 spline stress cracks
I make splines for a Harley Trike shop. 4 recent failures (clean straight break) at a c-clip groove I believe due to stress cracks and vibration. I propose adding more radius to the groove, but wonder if a different grade of steel will help too. Currently using 1045 CF. Any suggestions? 1050 pros and cons?
RE: 1045 spline stress cracks
How is the groove and spline machined?
Bead blasted?
Yes C-clip grooves and splines are stress concentrators and will generally initiate shaft failures. Bigger radii might help.
Nick
I love materials science!
Cory
