Live roller conveyor chain selection
I have to select the correct chain used between each roller of a live roller chain conveyor (that is that there is a loop of chain between each roller).
Should I divide my load by the number of roller since basically, the motor will rotate only one roller?
Hope my question is clear enough.
Thank you beforehand.
RT
RT
RE: Live roller conveyor chain selection
http://www.cemanet.org/publications/index.html
Don't forget about tensioning the chains also. I haven't used them but the Roll-Ring tensioners look like an easy way to tension chains on live roller conveyors.
http://www.renold.com.au/chains_b.htm
