power generator help
hi, does anyone have worked with power generators for audio applications? i need to know how much to derate a generator when working above 2600m altitude and some tips about generators when in audio applications
regards
killa
RE: power generator help
killabyte,
normal procedure is that the manufacturer of the genset should be able to provide these data.
regards
i usually rent those equipment but i need some general tips, cause i usully dont have specific info.
regards
killa
The general rule is derate 4%/1000ft increase in altitude.
Mike
There is significant differences for altitude de-rating factor applicable to power generator apparatus such as engine-generator, UPS, converter, etc. Please clarify the term "power generators" for audio applications?
To clarify, my post was in regards to engine-generators.
Mike
ANother thing that you must allow for when you palce gen sets at high altitudes is cooling systems.  If your radiator isn't sized correctly  you can bet that you generator will overheat due to the lack of oxygen at high altitudes. You tend to have a graeter drawdown at these high altitudes. You will usually have to make sure that you size your radiator larger than what the standard spec would be at sea level.  Also Make sure that you account for the type of fuel you'll be burning and (DO NOT) forget to account for the sulfur content in the fuel you'll be getting !
