temperature sensor network
Hi: I am new to the forum, I am Alejandro from Argentina. I was asked to build a low cost temperature sensor network.
The network will have 10 sensors separated 10 meters each.
I would like to hear your opinion about the technology to use, I know that 4-20 mA sensors are suitable but very expensive, 1-wire sensors can be an option.
Do you know any other low cost solution?.
Thank you in advance,
alejandro
RE: temperature sensor network
Hi Alejandro,
One of the cheapest sensors you can use is a thermistor with a negative temperature constant (NTC). They are small, they are cheap (a dollar apiece - or less), and they are non-linear.
They can be linearized with a series/parallel resistor over a limited temperature range (say -20 to +30 degrees, or 0 to 50 degrees) if you need that. If you evaluate the temperature with a computer, you can linearize in the computer program and the temperature range can then be more than 100 degrees celsius.
Google "NTC thermistor" for tons of more information.
Thank you very much for your help.
I do understand that NTC can be a cheap solution.
I was wondering how can I reach a CPU (for instance, a PLC) with that information (the measured temperature). That is to say, how can I "send" that temperature to a PLC that is 10 meters away from the sensor.
That is why I was considering 4-20mA and Dallas' 1-wire as options.
Best Regards,
Alejandro
Use the Barix BarioNet controller (www.barix.com) with the Dallas 1-wire sensors.  With a small extension module, the controller can connect to as many as 16 of these sensors for something like $400 total.  The controller can log data locally, display dynamic values on its built-in webserver, send data to a server, etc...
