Frames in Intralink
Frames in Intralink
Frames in Intralink
Hello All,
I do not know if you are aware that frames in Intralink are workspace related.  I was running ProE under one workspace, but had switched over to another to export a part from it.  Later I was having problems with a part, so I was undoing frames to get the part to work.  Little did I know I was loosing work in the other workspace instead of the workspace I thought I was correcting.
Tofflemire
