suspended slab vs. hollowcore for residential drive
I am designing a slab for a suspended garage and suspended drive/parking area for a custom home I am building.
Here is what the details are. The garage span is 24. Length is about 38 feet (3-car garage). The parking area is about 40 feet deep and is split into two spans 16' and 24'. Parking area is also about 38' long. I am using 160 psf live plus dead load and am planning on using 2" metal decking with underneath girders 6' on center (5 " slab). I am confident in my girder and decking calcs; however, is 160 psf low, medium or heavy?
Also, I am only vaguely familiar with hollowcore. Does it offer a lot of advantages?
Thank you! I am a new visitor to this website from South Carolina.
RE: suspended slab vs. hollowcore for residential drive
I have a similar question. I am building a custom plan as well with a suspended 3 car garage. The design of my home has a small kitchen pantry (4ft x 8ft) that would poke out into the garage. My builder is telling me we can't build on a suspended slab, but has no technical reason other than you just can't.
What do you guys think?
Jason
Also - may have thermal issues (insulation) but that can be detailed properly to control.
As for the loading 160psf does seem high. 50psf is correct for garages, but many do use garages for storage so jddoe has a good point. For light storage 125psf agrees with ASCE requirements.
Some producers may think your projects are too small, but that is not true of all manufacturers.
Here's a list of all PCI certified Hollowcore producers. http://www.pci.org/find/precaster_search.cfm
For 125psf load you'll likely be needing a 6"+2"topped or 8" untopped for a 24ft span.
