load latest option
load latest option
load latest option
Hi All
The 'load latest' button in my load options is greyed out no matter which of the three load options are picked.
Is there something I am missing?
Dave
RE: load latest option
Do you have a set of versioning rules defined?
-Dave
Everything should be designed as simple as possible, but not simpler.
Load lastest will only work if versioning rules are defined. It works off the versioning rules to determine what is the latest revision to load. Also, it doesn't cross directories, once it finds a match it loads it, even if there is a newer version in another directory down further in your search path.
"Fixed in the next release" should replace "Product First" as the PTC slogan.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
