Fall protection system - anchor design load
Does anyone know OSHA reference section numbers that spells out design load ( I believe it is 5000 pounds minimum load per lug) for fall protection system anchors?
Jay
RE: Fall protection system - anchor design load
Be careful with fall protection, there is more to it then just the load design, theres' fall geometry, types of lanyards, arresting loads on the unfortunate victim, retreival techniques etc.  You should check out www.dbisala.com for more information.
JJF
