Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Just to let you know...what a great site you have. I posted a pretty generic question yesterday and have had 8 responses already, anyway thanks again and keep up the good work..."
Geography
stevenmon (Marine/Ocean)
22 Nov 04 18:42
Hello I have a Marine (submersible) instrument design that calls for a Titanium Housing using a 316 Stainless Connector.  Would having these two materials in contact with each other cause problems or accelerate corrosion?
The 316 SS connector is threaded into the Titinaium Housing.
Thanks.
mshimko (Materials)
9 Dec 04 12:13
The example you describe may be in big trouble!
CRES will be subject to galvanic corrosion in this situation if the metals are immersed or otherwised wetted.  Furthermore, from your description I suspect the applicable surface area of the titanium is significantly greater than the CRES;  resulting in an even greater rate of attack.
Close Box
Join Eng-Tips® Today!
Join Us             Close
