question about skeleton
I created a skeleton for a cabinet design. It works very nicely for the individual parts and their overall lengths/width/height. However, now I want to control mounting holes that are patterned for the side panels.
I can adjust the pattern increments as a part length changes to spread the mounting holes apart if the cabinet gets taller or to make them closer together if the cabinet is shortened, but suppose I want the number of side mounting holes to change from 6 to 5 when the height of the cabinet is shortened to a certain length or shorter?
Thanks already,
SrG
Thanks already,
SrG
RE: question about skeleton
I had a similar problem which was resolved quite well in the thread # of instances in pattern table (Thread554-86497). Hope this helps!
Best regards,
Matthew Ian Loew
