Solidworks 2005 Launch Problem, Please Help.
hi, guys,
problems again! the pop up window said" Failed to intilize Visual Basic for Apps, equations and macros will not work. Are you low on disk space."when i click "ok" the dialog closes but so does solidworks. if u hae any inormation o how to solve this problem please reply.
Thank you !
Thank you !
RE: Solidworks 2005 Launch Problem, Please Help.
Either way try FAQ559-507.
If that doesn't work try FAQ559-908.
If that doesnt work try by FAQ559-488.
In all cases make sure your Anti-virus package is disabled when installing or repairoing SW.
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
c:\documents & settings\(login name)\local settings\"temp"
VBA and Dwgeditor (among other things) need this directory structure to work properly.
