Creating threads
Creating threads
Creating threads
Can someone help me with how to create actual (not cosmetic) threads on a shaft?
RE: Creating threads
Sure.  If you search this forum for "threads", you'll find plenty of posts.
Essentially, you'll want to create a helix for a path.  Sweep a positive form (such as a triangle or trapezoid, depending on your thread type) along the helix as a path.  You'll need to read the help menu for details on making such a sweep.
Good luck.
Jeff Mowry
Industrial Designhaus, LLC
http://www.industrialdesignhaus.com
