Creating derived configurations using design table
Can I create derived (not regular) configurations using design tables?
RE: Creating derived configurations using design table
I believe the column heading "$parent" will do it, minus the quotes.
Jason Capriotti
Smith & Nephew, Inc.
If still confused...
Manually create at least 2 configurations, "then" create the Design Table. It will layout the template you need to follow.
Ken
Yes you can.  I do it every day with sheet metal parts.
