nonsnappable to snappable
I've got a situation where someone created a project length Proposed Right-Of-Way file and from that, offset the Limit Of Disturbance line. I need to create shapes between the two lines (per property) .... usually a piece of cake task, right? Well, it turns out that all these lines are NONSNAPPABLE. Is there a key-in or mdl that will allow me to change the enire file to SNAPPABLE without having to do it one line at a time? I'm using Microstation/J.
RE: nonsnappable to snappable
GOOD LUCK
